This sound .......................
I will see you in the TOP 3 !
Greetz #503
Original von Memphis@MG
Original von Flo
your son can be proud of you! the gear ratio seems to be very long (compared to supermoto) but nevertheless the bike accelates very well
i wish you good luck for the upcoming races!!![]()
some days ago you mentioned (in a video?) that you change your main bearings after each weekend. is this still such a problem or have you improved the bearings?
thanks alot for documenting your great project! please keep on uploading!
cheers
flo
Original von Dr C
... I have stopped using the roller bearings, because when they seize, the secondary damages are expensive. I use normal ball bearings (C4) which tolerate the banana-shape of the crank when the tacho-needle touches 9k.
Original von Flowhy you use the very short 1st gear of the enduro models? i though for normal racetracks a longer first gear has advantages (not just use it for starting).
cheers
flo
Original von Tom-ek
congratulations !![]()
